dean, obviously you can't actually trace the wires inside the hull, but you can go to the choke and see if voltage on the choke while somebody pushes in on the key in the on position (or start position). And if there is voltage there, you either have a bad ground from the choke, or the choke is bad... If you don't have voltage there, you are going to have to remove the ignition switch and test the choke terminal. Otherwise, you have a broken wire in the hull... JMHO!
