hardwater fisherman
- Mar 19, 2010
- 1,725
I have 1976 40hp with electric start and a 5amp charging coil. I use a deep cycle battery for everything else. I have been using a car battery for starting, with 625 cca and it worked well but it is 8 years old now and not holding a charge well. My manual states I need a 12 volt battery with 70 ampere hour or better, with a minimum of 2 minutes cold starting capacity at 300 amperes discharge, zero degrees Fahrenheit, and a 10 second voltage reading of 7.5 volts. Will a Walmart marine starting battery 24m-625n with 500 cca work well enough or do I need a larger battery?.
