Hello again. My next project is putting in a new stereo head (speakers are ok). The PO wired the old head directly to the battery. The red and yellow wires are joined together near the head connector under the dash and then run as one red wire back to the battery. The ground wire also runs from the stereo head all the way back to the battery. Is this acceptable or should I rewire it using the fuse block? I know the stereo has 2 inline fuses already. Thanks.
