mustangmatt63
- May 30, 2015
- 3
I Put a 89 200 Yamaha on 22 Ft Open Fisher, Engine had No Harnesses or Sub Oil Tank, I Purchased New Engine Harness, Used (Good) Sub Oil Tank,2 missing Harnesses and New 704 Yamaha Binnacle, I Have The Engine Running but have No Clue how to Wire up Gauges, I have The Yamaha Manual But am Just lost as I Really do not Understand it,All The Gauges are New Universal Gauges, I have them wired together so far in Panel with the grounds and The Lighting wiring all in line, There are No Connectors on the Wiring harnesses at all (Except Main Engine Harness & Binnacle) and thats Finished...Basically What I need to know is I have 2 4 wire harnesses coming from engine1 is for Oil Tank I Believe(Blue-Black-Black&Red Stripe-Brown) then a Harness with a Yellow-Green-Yellow&Red-Green&Red)..Can Someone tell me where these 8 wires Go ?? I Believe The Blue Wire & Brown Wire go to Oil Pump on Tank..Other Then That I am Lost...Like I said There are No Connectors on Anything so it has to be Straight Wired...Any Help is Greatly Appreciated..I Have Tach-Trim-Speedo-Oil-Temp Gauges...THX in Advance for any help...
