It is very likely the bilge pump that is causing the issue since it is connected to the boat harness. When the boat is wet, the pump probably kicks in and the boat harness fuse is not big enough to handle the current requirements. Installing a larger fuse is not the answer unless the +12 and ground wires are large enough to handle that fuse. In a boat, the harness that feeds the console and all accessories except for the instruments is called the boat harness. The engine harness handles the engine, shift/throttle control box, and the instruments. If you do have an automatic bilge pump then it would be prudent to wire the automatic line directly to the battery through an appropriate size fuse.
