Ok so following the winterization of my boat, it won't start now. When I turn the key, it just clicks.
I have;
1. Purchased a new marine battery
2. Changed the negative terminal connection on the battery
3. Pulled off the power cable from the starter and used a jumper cable in its place
4. Pulled off the starter - had it bench tested and is working
5. Replaced solenoid.
Any ideas on what I can do next? Boat has a 5.0 Mercruiser.
I have;
