fishermanof93
- Feb 3, 2015
- 34
I have a small aluminum flat bottom and was thinking about adding a second battery. I don't have electric start but I have two locaters and a livewell on it. not sure if I will even need a second one or not but my trolling motor can be switched between 24 and 12 volt. I think I would get a significant amount of more power running as 24 but I don't know that for sure. what my question is, is it possible to hook these batteries up in series and parallel. so that I have the higher voltage and longer life for the electronics.also if they were in series I would assume I can just run a standard charger on one of them and they will both charge? I use to do a lot of car and stereo wiring so that's not a problem just having a problem thinking threw this. if the picture doesn't make since sorry I am not good with paint.
