GCartwright
- Jul 1, 2012
- 149
I'm looking at upgrading the audio system on a SeaRay 225 BR. I've never set up a system before so hopefully I can get some answers on doing this.
Currently I have the following components:
Kenwood KMR-D5558BT HU http://www.kenwood.com/ca/car/marine/kmr-d558bt/
(4)Infinity 612M speakers http://www.crutchfield.com/S-LNEWh5MS0Mv/p_108612M/Infinity-612M.html
I would like to add an amp and a sub to this and may try the diy sub route to keep cost down as I'm just looking for some decent sound at lower volume levels.
I have an old Rockford punch 400.4 amp that I pulled from an old car system years ago.
Manufacture specs...
RFG 1400A
Punch 400.4
4-channel "Punch" Amplifier.
Output Power
(4 ohms)
50W x 4.
Output Power
(2 ohms)
100W x 4.
Output Power Bridged
(4 ohms)
200W x 2.
Distortion Max
(4 ohms)
0.05%.
Frequency Response
(+/- 0.5dB)
20Hz - 20kHz.
Signal to Noise
(A-weighted)
>100dB.
Input Sensitivity (+0dB gain overlap)
150mV - 3V.
Bridgeable.
Pass-thru capacity.
4 Xcard capacity.
My questions are: is this amp suitable for the application?, I'm not sure how a 4 channel amp would be used for the speakers listed. I have room for a 18"w x 18"l x 14"h sub box .
Thanks
RFG 1400A
Punch 400.4
Output Power
(4 ohms)
50W x 4.
Output Power
(2 ohms)
100W x 4.
(4 ohms)
200W x 2.
Distortion Max
(4 ohms)
0.05%.
Frequency Response
(+/- 0.5dB)
20Hz - 20kHz.
Signal to Noise
(A-weighted)
>100dB.
150mV - 3V.
Bridgeable.
Pass-thru capacity.
4 Xcard capacity.
Thanks
