repeatedly fouling plug
lparkerjr1944
I have a 1996 evinrude 40H E40TLEUE The lower plug fouls out repeatedly I have checked that the fuel/oil mixture is correct and replaced the Plug several times. The gap is what is recommended. Carborators have been cleaned. Nothing worked so far the plug fouls whether I'm at an idle or running full out. Any suggestions?
GA_Boater
:welcome: aboard, lparker1944. Moved your thread to the Evinrude forum. You have a better chance for help here since it is something with the motor. Good luck.
Tim Frank
Three suggestions:
1) Buy an OEM manual; best investment you will make.
2) Read the Top Secret files at the top of this forum. There is a wealth of information and some great tips for effective troubleshooting.
3)
"and replaced the Plug several times"
In general, if you replace any part several times without getting any positive result, you are just guessing, and would be better to just open your wallet and your car window and throw the $$$$ out and get it over with.... :)
I know it is "only" spark plugs in this case, but that is still ~ $10- each time, and I'll bet that you've thrown out at least 4 perfectly good plugs.
Systematic troubleshooting will get you to the root cause of the problem and you'll know what really needs to be replaced....if anything.
Check the pulse line on your fuel pump. If it has raw fuel in it, the fuel pump may be leaking fuel into the crankcase, fouling the spark plug.
WrenchHead
You say the bottom plug fouls so that means you have at least one other plug. Therefore the problem is probably in the cylinder. Do you have only one carb? If so then it ain't the carb. As suggested do a compression test, you may have a bad piston ring. As another test, trade plug wires with the good plug and see if the problem moves. Leaking, or shorting out, plug wires will give you a weak spark and incomplete combustion.
boobie
What temperature is the motor coming up to when running ?? Especially at idle.
