johnnylama
- Jul 9, 2014
- 13
Hello.....I'm really hoping to get some help with this.
I need to get my boat out of my slip for the winter, and have an electrical problem I cant seem to fix.
2001 18- Bayliner Capri
90 hp 2 stroke Mercury Outboard (3 cyl)
6 month old battery...fully charged
Boat sat in the slip for about a month without being started. Bilge pump/float worked perfectly during this time. Replaced faulty starter solenoid over the summer but had no start up issues since.
Went to start up to boat on the trailer and here's what's happening:
1. Turn battery shut off switch on
2. Get power to instrument panel, lights, bilge switch and horn
3. Try to trim engine down or up.....everything dies
4. Everything stays dead until i turn battery shut off switch off...and then back on again
5. Repeat from 1
Also same thing happens on number 3 above if I try to turn the engine over.
Although the battery is fully charged, I figured I would try the above again with a battery jumper hooked up...just in case. Same results.
I've repeated the same exact steps at least 7 or 8 times with the same exact results each time.
I am no good at tracing electrical issues so I'm hoping that my description of what is happening will be enough for someone to make some recommendations.
Thanks in advance.
John
5. Repeat from 1
Thanks in advance.
John
