I was given a boat that had a Hummingbird depth finder but the coaxial cable had been chewed through by some critters. Is there an easy fix? Can the coax cables be spliced together? I notice that on one end there are 2 wires plus ground wrapped in foil but the other side has one wire plus ground wrapped in folder. There was some kind of connector between these, but it is not usable. Can these be spliced without this connector?
