HELP! How to wire johnson 25hp 1991?
lake tahoe
I have just bought a Johnson 25hp 1991, problem is there is no cables with the outboard and inside there is just a red connector. I need to know which wires I need to connect to give me ignition and starter to make the motor run and stop. Also the carburettor seems to be missing something off the front, should there be a choke flap or a filter attached to the front?
jauguston
If the 1991 30 hp Evinrude I just bought is any indication there is nothing on the intake end of the carb. I have the repair manual for it and the pictures don't show anything there.
Jim
