Slice of Life
- Apr 2, 2013
- 78
I have a 92 Mercruiser 5.7 350 MAG with Thunderbolt IV ignition that recently had the 15A ignition fuse blow when I tried to abruptly go to WOT from cruise. After getting it towed by a friend back to the slip, I replaced the fuse to find that as soon as I turn the ignition key the fuse blows immediately...most of the time. I'm getting electrical to all of the other switches (blower, bilge pump, lights, horn) but none of the gauges will come on. The kicker seems to be that it will not blow immediately every time I replace the fuse, and I even was able to start it once before the fuse blew again within a couple of minutes. The wire that goes to the fuse that is blowing is pink (faded red I guess) with the black line on it. Battery has sufficient voltage at 12.55.
Possibly a related problem is that it has been very stubborn on wanting to start lately, and that on one of the troubleshooting fuses I put in that stayed on going before it blew again, the engine did not want to start at all, but kept cranking and cranking. I even had a 10A that lasted a few mins before it blew when I was out of 15A fuses. I have a multimeter and see that I'm getting below .20 V on each of the 3 wires that go to the ignition. The starter is so damned hard to get to in this engine compartment I haven't messed with it yet. Any ideas? Thanks a bunch.
