luv2fish62
- Jun 10, 2010
- 35
[FONT="]Hi all. I am installing a HDS-5 Gen 2 and have a question about the power cable connections. The cable has a red, black, yellow and blue wire. I have the red connected to a buss bar that is switched with a battery switch and the black to a ground buss bar and I understand the blue is not connected. The yellow is where I am confused. My thinking is that the yellow is to be connected to an unswitched 12V positive source which provides continuous power to the unit when the battery is switched off. Does this provide power for a memory function? If so, when I turn the unit on will I still be required to accept the agreement statement each time that pops up on the screen after the unit is turned on?
Or am I totally off base in my line of thought?
Thanks for any help you guys can give.[/FONT]
