ericcarr2000
Ensign
- Mar 19, 2010
- 903
Im having a slight problem. At times when I turn on the converter switch, I can hear a slight humming coming from the breaker switch, it does go away but the last time I left the boat, I turned the converter switch on, came back to the boat a week later and noticed that the switch must have tripped somehow. I took the breaker panel off to check for loose wiring and everything was tight, no loose wires. Do you know what I could check for and where I might get a replacement breaker? It times it seems to trip the breaker. I just recently installed a new converter and this when it happened.
