1stgenbird
- Aug 5, 2009
- 397
My navigation lights haven't worked right for awhile. They are controlled by a 3 position push/pull switch. When pulled into the 1st position, nothing and in the 2nd position just the stern light. I suspected a defective switch because when I wiggled it when the stern light was on, the light would go out intermittently.
I bought a new switch but the lights still don't work any differently.
I disconnected the bow light thinking that was defective or the bulbs burnt out but when I held it across a 12v battery, it worked. I then metered out the wires to the bow light to be sure no breaks, and no problems there.
Hooking up the new switch, I get power (approx 2.6V) to the switch. In the 1st position, 2.6v to the stern light terminal, the 2nd position, both the light terminals get 2.6v. I then connected the lights and the stern light works in the 1st position but when I pull the switch into the 2nd position, both the light terminals drop to zero.
When I remove the bow light wire from the switch, the voltage works as I think it should. I suspect I have a bad bow light but it worked when I connected it to a battery. Any thoughts?
