carburetor is not electrically connected to the engine block.? wow that's confusing to me sorry, did you mean carb or choke?Most Choke Heaters are grounded through the Carburetor to the engine.
It is hard to image that the carburetor is not electrically connected to the engine block.
Try it without the dedicated ground, if it does not work, add the ground connection to the choke.
