I need to reinstall a bilge pump on my searay 1987 the pump is good is there but is disconnected, where should I connect this pump, and how any help or intructions thanks.
The pump should be powered directly to the battery through a float switch and a dedicated fuse.
Any manual On/Off Switches/Alarms you want to add to the circuit are convenience items and are not required.
