I am replacing the fuel sending unit on my below deck, 4 inch deep 18 gal fuel tank. I removed and inspected it and could not get the resistance of the potentiometer to cooperate so I put it back in while I find a replacement sender and gasket. I was happy that the white crud on the tank and gasket was easy to remove, but it leaks a little anyhow.
Any suggestions for a sealant for use with the new gasket and fuel level sending unit? A sealant that will be as easy to remove as the old stuff?
BTW, I was only able to find one replacement sending unit for such a shallow 4 inch deep tank.
Thanks in advance.
Thanks in advance.
