wpg manitoba
- Aug 15, 2012
- 69
I am thinking about moving my battery to the front of my boat to level the weight better. The wiring from the engine is very beefy, maybe something like 2 or 1 gauge? not sure. But I have a lot of extension cord wiring laying around and was thinking about using it to extend it another 10 feet or more so I can place the battery near the front of the boat. Basically the extension cords has 3 14 gauge wires in it so I was thinking of using one extension cord for each positive and negative. Is this a bad Idea?
I figure if its not enough I figure it won't turn over the motor, but since this is just a 30 hp 2 stroke I think I should be just fine.
I have used cheap jump start cables in the past which would not turn my truck engine over so if this set up doesn't work I figure it would be the same scenario.
