Condor1970
- Jun 9, 2014
- 195
Ok, after sitting for a week, I finally got done with my work on the outdrive, and the tried to run my 1989 3.0L Merc this morning.
This is the problem, but first I have a question.
When I turn to key to power on, but not start, everything is on and getting power. However, should there be 12v at the +/- contacts on the ignition coil itself?
If not, then I assume it comes from the alternator only, which makes sense. I checked continuity of the purple wire all the way from the alternator to the ignition coil, and it is fine. When I start the engine, the volt meter on the dash does jump, indicating the alternator is producing power.
The engine starts when I turn the key, but as soon as I release the start switch to normal on position, the power stops to the coil, and the engine quits immediately.
Any suggestions as to where I should start with this?
