Hi All,
Apologies if this is in the wrong location, first post.
I've been given this engine as a project no key no kill switch no diagrams ect.
I propose to fit a standard ignition switch, wire the choke to just a flick switch.
Where does the charge from the battery come from? Do I just run the purple wire straight to battery?
Im powering the ignition switch straight from battery, from here I feed the ignition with 12volts ext, can get the engine to run no problems but currently i have no charge going back to the battery?
The Kill switch was removed so should I replace that? these 2 red wires connected to the spade i assume once connected to it?
Massive thanks for any help given.
http://postimg.org/image/5djbdj4jn/
http://s7.postimg.org/y5g7iemjf/reg.jpg
