broncodriver
- Jul 17, 2014
- 8
Had to replace the factory gauges (VDO only made 1 year for Bayliner one piece molded set with circuit card and not repairable (I sent them in)) on a 2001 Bayliner w/Mercruiser 5.0 engine. 1st one worked for 10 minutes and quit so I thought it was manufacture defect and swapped it out, the next one (this spring) worked for about 10 minutes again and quit. So, I thought it might be the boat wiring and I ran new wires from the ignition, ground and neg side of the coil to the 3rd tachometer.
All other gauges share this hot, lighting and ground wires all work without any issues. Again this tach worked for 10 minutes and quit.
Is there a resistor or something that I need? I'm guessing the coil keeps frying them? Fuse does not burn out, and yes the tach is set on 8C/4P, boat is all orginal factory, nothing special about the coil, not EFI engine etc.
Help this is getting expensive!!
