Hello all. I have a Lowrance Elite-5 HDI And a Cobra Marine VHF MR F55-D The VHF radio came with a dongle with a simple red and black wire coming from it. Book says that red is positive black is negative. Now on the lowrance I have Yellow TX (+) Blue TX (-) Shield (Ground) My question is would I use the yellow and connect it to the red on the VHF then blue to the negative on the VHF? But I also was thinking that the yellow might be high power transmit and blue might be low power transmit then I would use the shield (ground) to the black from the VHF. So would I only the yellow or only the blue from the lowrance and disregard the one I'm not using like if I'm using yellow disregard blue or the other way around. Then connect the shield from the gps to the black on the VHF. Or take the yellow to the red and blue to the black and then ground out the shield (ground) to a common ground source? There's nothing that specifically states what those wires from the lowrance are. Either the yellow and blue are high and low power transmit wires or they are the positive and ground wires I'm looking for. Thanks in advance to any one who can help.
