Hi All<br /><br />My second hand fishing boat just purchased has a Humminbird cheap and basisc fishfinder fitted,ok for a backup but I'm used to a more detailed sounder.........<br /><br />My hull however has a Furuno through hull transducer fitted with a fairng cover to reduce drag,this has been left intact and in place when a previous owner must have removed the Furuno head unit..........<br /><br />The transducer connector plug has a ten pin configuratin and what I would like to know is will this transducer be compatible with any other Fishfinder makes? and if so can you please advise which ones?<br /><br />Or do I need to purchase another Furuno?<br /><br />Many thanks from Rob in the UK
