I believe it was you rodbolt who informed me that my 2004 yam 150 4stroke has a built in rectifier for running 2 batteries and charging them simultaniously while running but isolating them when the engine is off. If this is correct, and I believe it is, will both batteries see the same charging current when the engine is running?<br />The reason I ask is that the battery used for accessories, the one connected to the 10ga wire, does not seem to get a full charge as quickly as the starting battery.
