Re: Garmin or Magellan? Comments please.
We use Garmins at work, forestry-related. They make a tough/good GPS, although we use Etrexs (which have less bells and whistle than the Vista's and can be bought for less than $100). We had a Magellan too, when we first started using GPS, and it was accurate but a little less user-friendly. <br /><br />One bit of advice, the software and hardware is not compatable. If you go Garmin, stay Garmin. Your Magellan stuff won't work with a Garmin. <br /><br />O/W, 1 GPS unit is pretty much the same. All they do is triangulate signals from satellites in near-earth orbit. Everything else is extra.<br /><br />Tips: Get a unit that uses AAs, not AAAs. Cheaper to buy AAs and they last longer. Get a unit that can download to a PC via a PC interface cable if you want to download or upload info, O/W you are dead in the water. The Etrexs have these features, but not some of the GEKOs (for example).
