Constancia
- Jan 13, 2004
- 35
I'm running a Garmin 128 fixed mount GPS on my boat. Have a new Garmin 29 antenna mounted up on the T-top. Gets great reception. I also have a Garmin GPS 76map handheld as a back-up unit and occasionally use it, as well.<br /><br />I bought the BNC to MCX cable adapter that will allow me to plug the handheld into the external antenna on the T-top. Haven't tried it yet, but it should work just fine. <br /><br />So here's my question: If I installed a T-connector on the coax BNC connector between the antenna and the fixed mount unit, could I run the handheld off it at the same time? In other words, run both GPS devices off the same antenna at the same time? I haven't tried this yet, but don't see why it wouldn't work, unless it screws up impedance or something by adding a second device to the cabling. Anybody running two devices off the same antenna? Or should they only be run one device-one antenna?<br /><br />The reason for this is that the handheld captures more data and allows me to upload/download from Blue Water charts on my computer. The fixed mount doesn't. <br /><br />Thanks!<br />Stuart
