Ben Konopacky
- Apr 5, 2004
- 296
Is there any way that I can check this unit(not sensor)out to see if it is working in the spedo mode by applying res. or v. to the unit in place of the magnetic spinner.also the same for the temp.sensor.I would like to know how to bench check the sensors , suspect bad cable ,cable is potted. The FF works. Thanks for the help. Ben
