Re: GPS Antenna Mounting Height
I wouldn't argue a bit with either of them. I like to put them up a bit, but as long as they have a good unobstructed view of most of the sky its not that important. They can receive through canvas tops and through glass, hard tops are a different matter. Also, if you have, or intend to install, radar you need to either get the GPS antenna above or below it, but not in line with the radar's beam. Other than that you can put them most anywhere.<br /><br />One thing though, you said on the side of a cuddy, and that can be problematic. If the mounting blocks half of the view, which is to say you just put it down on the side of a cabin wall, then you will have considerable reduced sky-view. <br /><br />On my boat, which has other antennas (2 VHF and a Cell) mounted as well as Radar, I used a standard mount on the side of the cabin wall and then an inexpensive extension to raise it up to just above the canvas top. This gave me a complete sky view, with the exception of the very small area blocked by the radar and other antennas, while holding the GPS antenna below the radar's beam. It also allows me to tilt it down when towing. Its not a clearance problem by the way, the Radar is the highest part when we tow, its to lessen bug splatter. Really!<br /><br />
<br /><br />Anyway the picture is just there to give you an alternative idea. <br /><br />Thom
