Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
How to connect two trolling batteries together.
  • How to connect two trolling batteries together.
    I just bought another deep cycle battery for my trolling (12V) motor, I was wondering how to connect both batteries together so I get more trolling time (not more volts.2. Question two I have a three bank onboard charger for my batteries that I also just bought.If I was to connect my batteries together how would I connect the charger to it ? - Would I connect the leads to on deep cyclebattery to charger both of them ? - Would I put a lead to each of the two batteries ?Any help would be greatly appreciated guys..Here is the charger that I bought:XPS 5/5/5you can see it here: Web site for Battery Charger
    Re: How to connect two trolling batteries together.
    I would suggest some kind of switch that will just allow you to switch from one battery to the other when the first one is dead. It's not a good idea to wire a new battery in parallel with an old one, especially if they are a different brand/capacity.
    • #3
      http://www.iboats.com/cgi-bin/ubb/ul...;f=36;t=000021 Good luck.
      sigpic
      • #4
        I have the same setup although at I only have a dual bank charger as I wasn't thinking clear when I purchased it a year ago. I added a blue sea battery switch. This allows you to switch between bat1 bat2 both or off. I put inline breakers in front of each battery. The switch requires just 3 leads bat1 pos bat2 pos and the switched output, which you just connect to your trolling motor connection. As for your charger you would connect direct to the batteries. Connect out1 to batt1 pos and neg, then do the same for bat2 and bat3. Now bat1 and bat2 will have to have a jumper connected across both the neg terminals rated or sized to what you have already. This may seem strange as the the neg leads from the battery charger could be connected to one of the two but I wouldn't. So in short you will have 2 neg connections to one of the batteries, 3 neg connections to the other battery. The extra connecton is the system ground of the trolling motor. Use the battery switch to select 1 or 2. I personlly do not use both as if you have one battery going bad it will take the other one with it "as previously stated by the above post". When charging select off to disconnect the trolling motor, this way you do not have to unplug it as charging batteries with the trolling motor connected can in some cases damage the trolling motor. If you do not connect the 3 output to your starting battery make sure you connect it to one of the deep cycle batteries. I beleive the XPS is similar to the mariner pro and uses distributive charging. That is you have 15 amps total, so as one battery is returning to 100% the avalible current will be used on the other outputs. I hope I didn't confuse you. Good luckSingleShot
        • #5
          I an no battery expert but I believe you can wire them together. A fishing buddy of mine has a boat with a 12v tm and he told me he wired them together. It is a little different than wiring them in a series for 24 volt but am not sure what.Go to www.thehulltruth.com and there are several threads there on this situation.
          Back to Top
