I just bought a new tracker txw175 bass boat. I had an upgrade to 70 lb. thrust trolling motor.
I have three batteries two for trolling motor 24 volt and one for cranking 12 volt.
They tell me the on board charger will charge one of the trolling motor batteries and the cranking battery, and to charge the third trolling motor battery separately. Can I do both chargings at the same. I was told to disconnect the third battery
when I do the charging is the correct.
