Re: booming sound system on outboard yamaha 115
24 amps is ~300 Watts Absolute Max when the engine is reved up. Much less at idle. Nothing when Stopped.
Some of that (~50w) will be needed just to power the engine ignition circuits and budget another 50 to charge the battery back up.
Allow another 50 for all the gauges and lights and other stuff you may have on board.
That leaves you ~150w for your audio equipment.
Keep the AMPs below 50 Watts per side and you might just make it,
but it will be straining the alternator if you keep it up continuously.
Keep the music at conversational levels and everyone on the lake will appreciate it!
If you dedicate one deep cycle battery to the sound system while anchored;
The alternator will recharge the battery when you restart the engine with the music OFF.
Keep the engine reved up and the batteries should be fully charged it in less than 10 hours.
You are going to need a Shore Powered Charger!
