81 Checkmate
- Jul 20, 2010
- 1,360
Installed my stereo this past Sunday?.All worked fine the way I hooked it up, then last night I went to try it and battery was dead..completely dead.
Here is what I did?I have a switch on my panel that is marked Acc?so I wanted my stereo hooked to the switch?so I wired it directly to the switch . Turn key to run and flip the switch and the power light above the switch comes on and the stereo works.
Now here is where I messed up??.there is a main feed wire that feeds all the panel switches that is hooked up to the bottom terminal of the key switch?so when the key is turned to run all the switches work.
I wanted to have this panel live all the time, so I didn?t have to turn the key to run?so I moved the main feed wire to the top terminal of the key switch where the main red battery feed comes in?I was thinking this way the panel has power at all times, it worked that way, but drain the battery.
So now I hook up the battery charger and it reads zero and will not charge?so I switched the panel feed back to bottom terminal and as soon as I did the battery started charging. So obviously I cannot hook it up that way.
Question - How can I hook up the switch panel so it?s live all the time so I don?t have to turn the key to run to make the switches work?like the blower/ bilge/ lights/ ACC
Some Pic's
The big red wire is the battery feed on the key switch
The pink double wire with the blue crimp conector is the main panel wire on the key switch. The panel is dasiey chained together
Some Pic's
