juicegoose
- Mar 30, 2013
- 105
I recently moved my batteries from the rear of the boat up to the center console(07 2110 nautic star). While I was under the dash I noticed that the black common wire that goes from the gauges and switches back into the main wire harness was loose and had obvious signs that at one point it had overheated.
I will begin some basic troubleshooting to ensure there isn't still a fault but does anyone have a broad Idea of what could cause this? The only fuse in the system is a 30a main on the power feed to the panel and gauges.
Also If I wanted to replace the wire with fresh wire how do I remove the existing wire out of the harness connectors?
