full_boat_redo
- Apr 24, 2014
- 9
Hi all and thank is advance for your help and guidance. I have a 29 ft 1980 Lakes Craft Pontoon boat with a 140 I/O motor and am in the process of redoing the flooring, seats and electrical. (over the years what wiring is left in tact in the helm is a bit of a hodge podge of splices and all kinds of fun. I am installing and ok on the process for installing a new fuse block switches and the associated lights and electronics. What I need help with is identifying what wiring harness I should obtain to connect the control throttle to the engine - as I am replacing the helm and moving to a new binnacle control box (BRP/OMC 5006186).
The existing wiring from the engine for the ignition does not utilze any plugs, again a series of questionable splices. The new control box has 2 plugs attached 1 is a Deutsch DT04-6P that appears to connect the wiring to the ignition and a Deutsch DT04-3P that looks to be for the tilt and trim. Seperate plug for the auidible warning on start has a Deutsch DT04-2P for connection to some check guage or audible horn driver (I have neither that I can find...)
I had a reccomendation to get the wiring harness OMC vintage part 981877 but the peson who suggested had no idea if it would connect to my control box plug, they also referenced a OMC vintage part 981448 for the tilt trim connection?
Any idea if the above would work or other suggestions ( or should I ty to get the correponding female plugs for the above Deutsch plugs mentioned and splice to existing wiring?)
