Hey guys this is my first post here on this forum and i hope I could get som expertise from you!
I bought a 2005 Four winns 180 horizon 4.3 GL last year and I love it .. Today I took it out from winter storage and wanted to check on some stuff and then fire it up. Everything went really smooth, the engine started easily and run nicely. After a while I would check the engine temperature, I see that all the gauges behave very strange. One moment it shows the right value but after a few seconds they stand completely wrong and a moment later they change again and so continues. So none of the gauges works as they should. A little later, I decide to try the stereo and discover that it does not start at all. I kill the engine and test the horn. It is completely dead while the tank gauge jerk at the same moment I press the horn button and the leds inside the other buttons lights up brighter. The only thing that works well is the outdrive tilt, engine starter and engine room fan. What is going on ? I checked all the wiring and connectors under the steering wheel and fuses with no luck. Is there any other fuses or relays in the engine compartment? Could it be a ground issue?
I remember that Before the Winter storage I short circuit the battery for a sec or two when I removed my second one, could that caused this weird problem.
I hope somebody have some advice out there Appreciate all the help I can get. Thanks and excuse my little bad English.
