I just put in a new horn and ran it from an additional powerline I had just installed - with a 2.5 amp fuse recommended for the running light- near the 12v battery. I powered the horn from this new wiring for my running/new anchor lights. All worked OK, but a little while later I blew a fuse, which I later realized was probably caused by testing the horn. I installed another fuse and it blew as well. So I went on line and looked at the specs of my new horn, only to read its rated at 4 amps. So I'm pretty sure that is what blew the fuse. On the third fuse, the light still works many hours later, and I haven't honked the horn, except for one real quick beep.
My question is can I wire in another second line (y it before the 2 amp fuse) and have a second fuse for the horn at 4 amps, so they are both on their own fuse and independent lines, but not having to pop for more battery connectors. Also, do I need to have a second/independent neg/ground line. Or can I keep both neg/grounds on the same line.
Last question. If the horn is rated a 4 amps, do you buy a four amp fuse? Do I even need a fuse for a horn? I know the running light recommended a fuse, and that is why I installed one. Thanks for any help!
