Re: trolling motor control cable
First of all welcome to iboats :welcome: good to have you aboard.
I have rebuilt a few trolling motors, but not your particular type. However, it is either a single steering cable setup or a push-pull dual wire model. If you could take some pictures and let us see what you see, we can narrow it down and give better suggestions and part availability... Even if there are no parts available for your specific type, other trolling motor manufactures use a lot of the same setups and therefore you can cross over to something that will work most of the time... Let's see some pictures of the head unit with shaft and motor AND the foot control unit as well...
