Re: Wiring a 30Amp A/C Breaker...Help
Thanks!!!
I think You just gave me the missing part. The white has to be broken in that main and not just the black. So my whites have to be on the other side of the main. see below...
Shore 2 should be separate
I did also find a GI that states on galvanic Isolator for 2 30A shore feeds
Yandina Galvanic Isolator
50 Amps AC Continuous Rating, 30 Amps DC
Designed for use on any Shore Power Connection up to 50 Amps
Only (1) is Required for Dual 30 Amp Connections
I'm going to look at the same panel in a friends boat tomororow just to verify but I think you showed me the issue.
