I am fairly new to this site but not new to stereo systems and everything that go along with them. With that said here is what I am running, (1)Kicker ZX750.1, (1)Kicker ZX350.4, and (1)Kicker DX200.4 amplifiers. All three are mounted on an amp rack and all run off distribution blocks with 8 and 4 gauge running to the correct amps and 1/0 gauge wire running to the batteries. The old setup had one amp split between two batteries and batteries wired in parallel. It does have a perko switch between both the batteries also. My question is, where do I hook the 1/0 gauge wire to? I see on here that there are a lot of mixed opinions whether to run the amps off the COM side of the perko switch or battery two. What is everyone's opinion on that? Can you also explain the pros and cons of doing it either way? Thank you!
