the float switch I had was a rule and it was a 14 amp. the one that came in is a rule also at 20 amp max , this will be hooked up the same way to one 12 volt battery. will max amps won't pose a problem ?
no i just bought a float switch cuz the old one wouldn't shut off unless i flipped the float a few times.....the pump is fine . the old one was a 14 amp but this new one says it's good for a 12,24and 36 volt system .
started to install the float switch but ran out of time.......I noticed the two wires coming out of the switch has no pos. or neg. assuming
any wire will work for hot. also had to change out the inline glass fuse(very corroded) to the flat blade inline. should I start with a 15 amp fuse?
