Re: batteries in parrallel
I don't think I'd parallel them. There's no advantage that I can see. You still have the same stored energy whether they're working one at a time or twinned together. I wouldn't risk a good battery if the other decided not to play nice in the sand box. Bite the bullet and buy a switch that will allow you to switch between batteries and yet will still allow a parallel switch position should both batteries get exhausted. (OFF - 1 - 2 - BOTH) Any voltage imbalance between batteries in parallel will add a current flow between the batteries. When one fails completely from, for example shorted plates, the other will be called on to supply "short circuit" current levels and will deplete quickly. I like knowing that with a switch isolating my batteries, I've always got a fresh reserve if there's an engine problem or a battery failure. I rotate their use each time I'm out, sometimes every couple of hours, just for reassurance. - Grandad
