Hi,
I just bought a Tahoe 220 deck boat that had a rusted out JVC stereo in it that didn't work right, and barely powered any of the speakers. So I decided to buy a Clarion M109. I was hoping the wiring would be easy, but not so much.
As I carefully removed the JVC, I labeled all the speaker wires and moved them to the side. What I was left with was 3 wires coming out of a "Fuse and Filter Box". Green, Black and White. The JVC red was connected to green. The JVC black was connected to black. White was unconnected.
The M109 has a variety of connectors that seem to go to power. Just to see if it powered on I hooked up the Yellow 3amp and the Red to the Green coming out of the box. This is what the JVC seemed to use for power. I hooked up the black to black, this was the JVC's ground. And I hooked up all the speakers, those colors all matched.
I turned on my Battery Box switch to Both, put my key in and switched to the Accessory position. Pressed the SRC button on the Clarion...and nothing. I did the reset procedure, still nothing. Any ideas?
