Re: 5.7 mercruiser add 2nd battery/switch
BruceB58 said:
Add-A-Battery Kit - 120A - Blue Sea Systems
Agree, and that's the kit most folks go with. However there is more than 1 way to wire a boat, especially batteries. And the switch that comes with it is a simple On/Off switch. And you can use that switch to either combine batteries in case of an emergency (dead main), Or you can use it as a disconnect, but not both.
Another way to do it, and how I did my last boat, is I use the same Blue Seas ACR that comes in that pack, but instead I use a 1/2/ALL/OFF battery switch. And the way I wired mine up is my main battery is #1, from the main there is another wire that runs over to the ACR, and from the ACR to the 2nd battery. And then the 2nd battery is also paralleled to #2 on the switch. (I think I explained that right).
Now the way it works is when your OFF, all batteries are disconnected from everything except for my bilge pumps. (those always stay powered up, no matter what). When I turn the switch to 1, the main battery connects to the engine. And when you start the engine the engine charges the main until its full, and then the ACR kicks the charge over to the 2nd battery. The way the boat is wired, is the engine and the bilge pump is connected to the main. Everything else is connected to #2. I can run all my lights and stereo and GPS until the 2nd is dead, and the main will start every time. And in the event the main does die, I can flip the switch to #2 in order to bypass the ACR and combine the batteries for emergency starting.
That's how I did my last one.
