Hello,
The motor I am working on is a 1984 Johnson 25 hp model number J25RLCRD, when I connect the battery, the starter engages while the key is in the off position. The wiring could be wrong, I had it apart and lost my notes. Here is what I have on the solenoid:
Battery Positive to solenoid (Big post)
Solenoid to starter (Opposite Big post on solenoid from battery positive)
Solenoid to starter bracket (grounded, small post adjacent to big post going to starter)
I have three remaining wires that were on the solenoid that I am not sure where they were, but this is what I tried:
A Red from the key switch to the solenoid. (Adjacent of battery positive small post).
A Red jumper with a 20 amp in line fuse going from big post (with wire from battery positive) to adjacent small post.
A Purple coming from the 2 ignition coils and power pack going to small post adjacent battery positive.
I have cleaned all connections, The key switch is grounded and only has 2 wires coming from it. The battery is grounded to the starter bracket. Obviously the starter is getting constant power, but I do not know how, either through solenoid or key switch. Before I can test anything I need to know the correct wiring for 3 wires in question to the solenoid. Also, when I disconnect the jumper wire with the 20 amp fuse, I get nothing when I turn the key, but at least I can connect the battery. CAN ANYONE TELL ME WHERE THE 3 WIRES IN QUESTION GO ON THE SOLENOID? (middle paragraph) Thank you.
