Re: Batteries
I've not been able to get to the lake much--twice in two years.
I charge my batteries on-board, but I now have three dead batteries ...
If by "I charge my batteries on-board" means that you charge them using the alternator when the engine is running, and you only run the engine once a year; That is the problem!
If you mean that you have an On-Board charger that is powered by shore power and the charger is an "Old School" type that does not have a maintenance mode; that is the problem!
If the charger is a smart charger with a Maintenance mode that only charges for a second or two every few minutes, I would ask how often you have checked the water in the batteries.
I suspect that the batteries were not fully charged and were outside and frozen for a winter or two. Certain Death!
I have an Interstate battery that is three years old.
It is spending the winter in my attached garage, a cool 50-60 degrees, but not frozen.
I check the voltage abut once a month. It was charged back in October and it is still reading 12.7v.
If the voltage drops to 12.5v, I will top off the charge.
Otherwise, it will get topped off again in May before it goes back in the boat.
I use the boat at least 20 times between May and October.
Batteries require that they be charged and watered at regular intervals.
Every three months or so is reasonable. Every other year is not.
