As summer passed I would have to "jiggle" the power cable to the shore power to get it to turn on, and from time to time it would turn off even with everything secured. The trick is to slightly turn the power cord backward as if you were unlocking it to take it off. Never had problems with the A/C so I tried swapping cables and no change in behavior. I'm fairly certain that it's just the inlet that is the issue. The cable swap to me sort of proves it, and I've heard from others it's the inlet.
My question is, is there a repair option or is it best to just replace the entire thing? I'll pull it out and check for loose connections, but I'm not sure what causes these things to fail. Do the blades get thin or other possibilities that could cause a short? (I want to fix it right, don't want some electrical hazard.)
I don't want to replace the inlet because I'm not sure how universal these things are. Don't want gaps between the 2 plugs or anything. Unfortunately the boat is 3 hours away and I have no pictures so I'm not completely sure what is in there.
Any advice is appreciated.
