Will this work? All the listing I see show it from 1976 to 1983 outboard models.
Does it require the wiring kit #173602 or 173611 to install it?
The only gauge I have is a tach, hour gauge has never worked. I do have a fuse panel that runs other equipment, I'll pull the 12v from that.
It seemed confusing that they stated the harness needed to be used, or simplified the install.
Thanks Silvertip. This is the console, 1973 Starcraft Mariner, 1985 Evinrude 90 VRO.
