BrokeLoser
- Apr 28, 2013
- 52
My not so old 597 HD DI unit shows 8.4v on screen then shuts itself off. I test for voltage at the battery and the battery tests at 11.66v...I test at the fish finder mount contacts and it tests at 11.65v so I know I'm not losing voltage in my cabling.
It's mounted in my kayak with the 10' lead that it came with with no added cable and wired straight to the battery on a 5 amp fuse. I have been using this unit for nearly two years and it has worked fine...I haven't changed anything that may have caused the issue.
Your thoughts?
Your thoughts?
